Define Kinematic Chains about Machine tool builder
Dear all
I am using NX 10.0.3.5 , I create new machine(Millturn) in Machine tool builder , I found different on the Define Kinematic Chains ,that is my kinematic chains loss 【Coordinate Axes】Option ,
which section I must adjustment?
Thanks a lot!!
Someone can be help ?
Re: Define Kinematic Chains about Machine tool builder
the 'Coordinate Axes' option depends on, if the coordinate axes are orthogonal or not.
In case of orthogonal, then this setting is not required and disappears. In case of non-orthognal, then the system gives the ability to select a orthogonal coordinate system.
Thomas
Hi Thomas,
Thank you for your detailed explanation,
Thanks for your help!
