Delete all tools of a prt file via journal
Recently i've create a custom library tools.
I need to configure different tools chargers according to the type of piece. I've create diferents journals to retrieve the specified tools to a exact position on a tool charger. but i don't find the way to previously delete all tool of the charger.
The only way i proceed is previously select all objetcs and delete it
Re: Delete all tools of a prt file via journal
Esteemed Contributor
I would cycle through the CAMSetup.CAMGroupCollection and delete any group of type NXOpen.CAM.Tool
Attached is a journal that will delete all the tools in the work part. Remember, when you delete a tool, all of the operations under that tool in the tool view are also deleted. There is no confirmation check, but you have Undo if you run it by mistake.
I saw some issues with operations in the Unused Items (NONE) group. Please let me know if it works for you.
Mark Rief
Retired Siemens
Hello Mark!
Thanks for your reply
The journal works perfectly, it's exactly what I need
