Deleting detached stock from IPW
Does anyone have any tricks for removing detached stock from your IPW? I have to create dummy operations to get rid of the stock so that I do not see holder collisions in verify during subsequent operations.
I usually avoid this by trying to make sure everything turns into chips without leaving slugs, but I have some legacy parts that there is no time to reprogram.
I used to use Vericut, and you could simply pick what you wanted to delete or keep.
I see this post below from a few years back discussing the issue, and an ER 6789464
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/Split-IPW/m-p/3397...
Glenn Balon
Production: NX 12.0.2 MP10 Primarily CAM
1 REPLY 1
Re: Deleting detached stock from IPW
Hi Glenn,
in Nx12.0.2, we implemented a preview functionality to automatically achieve this. If you are interested, please drop me a personal message and I will supply information how to activate the functionality.
Best regards.
Claus
NX CAM Product Manager
