Dialog Sizes
when I resize e.g. an operation dialog in its width, NX never remembers the width, but I always have to resize again.
Does anyone know anything or if NX should remember dialog sizes?
Thanks!
Best wishes,
Joachim
In production NX 12.0.1.7 D2
In testing NX 12.0.1.7 MP4
10 REPLIES 10
Re: Dialog Sizes
No, NX deosn't remember dialog sizes.
There is a customer default to change the default width from 100% to another value, that's all.
Re: Dialog Sizes
Hi Stefan,
thanks.
For all: the Customer Default width is located in Gateway -> User Interface -> Options -> Dialog Width and is set to 100%. Thus it impacts all dialogs.
Best wishes,
Joachim
Re: Dialog Sizes
In general, the width is not remembered. However, in cases where we know this is really annoying, we can do it. For example, we remember the width of the UDE dialog for the current session, because users almost always stretch it to see the UDE text.
Is there a particular dialog that is causing pain?
Mark Rief
Retired Siemens
Re: Dialog Sizes
Hi Mark,
I am working on one of the feedbacks of our CAM-Anwendertreffen 2016.
My first task was to check what options we have. The next task will be to ask the users of the corresponding feedback group for more specifics. I would get back to you, when I know more.
Thanks!
Best wishes,
Joachim
Re: Dialog Sizes
The dialog to edit the machining data comes to my mind when I think about a dialog that is always too narrow to work with.
Another one is the result dialog for retrieving tools from the library.
It would be good to have the ability to enable dialog size remembering from within the dialog, like creating dialog favorites or showing less options, something like pin-dialog-size Smiley Wink
I will create an ER for this and post its ID here.
Re: Dialog Sizes
ER#7961860 "remember dialog size individually" has been created.
ER text:
                            ER Template
* Short Description of desired enhancement: <Problem rather than a solution>
    It is impossible to have NX remember the size of certain dialogues if they are made taller and/or wider
* What activity in your process is the product not able to currently handle?
    We want to stop having to resize dialogues every time we use them
* What result are you trying to achieve? (Please provide as many details as possible.)
    We what to have dialogues remember their size across sessions
    For example, the dialog to edit the machining data library in manufacturing is always too small and doesn''t keep its size if resized
* Do you currently have a workaround?
    No
* Do you have a proposal for the solution you envision Siemens PLM providing for this capability?
    Add an option, like pin-dialog-size to the context menu in the top left-hand corner of each dialog
    This setting should be remembered by the dialog memory
* What is the level of productivity gained from such an enhancement?
    HIGH, reduce the time to resize dialogues to be able to work with them efficiently, usability
* Other information:
    Talk to Mark Rief, NX CAM Customer Success department, for further examples, he collects them at the Siemens PLM Community forum
Ask GTAC to be added to this ER if it is of interest to you.
Re: Dialog Sizes
Generally the dialogs with lists of found library objects are too narrow and not all columns are visible, we always have to resize them.
Another dialog is the one to specify collision pairs in IS&V, which I must always stretch to have all columns fully visible.
I have now submitted another IR for an ER to have more control over the dialog memory and size for each dialog individually. I will post the ER ID here after it has been accepted.
Re: Dialog Sizes
This one should remember its width for the current NX session.
Mark Rief
Retired Siemens
Re: Dialog Sizes
Work instruction dialogue needs stretched open too
Dennis Rathi
Creations Unlimited
