Did spiral cut pattern for area milling make it into 11.0.1?
In a pdf from last summer's PLM World event (Manish Patel?) I saw slide which showed a spiral stepover in area milling.  Did that cut pattern make it into 11.0.1?  I am not seeing it so I am wondering if it was left out or if it is preview project.
NX 11.0.2
Re: Did spiral cut pattern for area milling make it into 11.0.1?
Sprial in area milling is still only available for EAP testers. I expect it to be released in NX 11.0.2.
Mark Rief
Retired Siemens
Can we see a picture of this path?
NX11.0.1
NX 11.0.2
How is this different than Follow prephiery with outward
This will put this spiral shape on any face?
What about the "spiral" drive method?
NX11.0.1
A simple case using a bullnose mill
Mark Rief
Retired Siemens
There are no stepovers
It might, but you may not like it. Many shapes (C, L, islands) can lead to an unacceptable pattern. This is targeted at more basic shapes.
No plans to change this. The existing spiral drive is a true spiral for a circular shape.
Mark Rief
Retired Siemens
