Directory saved Edit Machining Data Libraries
Which directory is saved in the Edit Machining Data Libraries settings?
I need to take this to another computer.
Re: Directory saved Edit Machining Data Libraries
Search the NX syslog for the feeds and speeds directory variable.
I would suggest to use a centralized configuration based on the NX_Custom package mentioned in the "customization and programming" forum for multiple computers. This will allow you to not have to copy files between systems.
