Do you use LinkedIn? More "Top Shops" are using it.
Siemens Genius Siemens Genius
Siemens Genius
Modern Machine Shop recently added the post, Top Shops Look to LinkedIn, to their blog. Based on the recent 2013 Top Shop benchmark survey, manufacturers are using more social media to promote themselves. Nearly 23 percent of this year's top performances use social media. Here are more results from the survey - Top Shops' Secrets to Success. If you use LinkedIn, there is a quite active NX Users (Formerly Unigraphics) Siemens PLM group. You might want to check it out.
Back to the original question: Do you use LinkedIn?
Make Better Parts Faster!
Aaron Frankel (Community Manager)
