[Drilling] Hole selection method inquiry
Solution Partner Innovator Solution Partner Innovator
Hi
I have a question.
Is there any way to select the minimum diameter and maximum diameter of the hole selection method in Hole_Making?
This has been done in previous drilling operations.
Is there any way to select a hole in this way?
Re: [Drilling] Hole selection method inquiry
The modern way in NX to select holes by sizes is to first recognize step holes and then group them through the Feature Navigator. Look at this Tech Tip article created by Bill Storrs:
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/More-effic...
This will show you how to use the Machining Feature Navigator for hole recognition. You will be able to put these grouped features into the Geometry View of the Operation Navigator and then apply Hole Making operations to them.
Hi kimies_saida,
I am aware of the drill capability you mentioned.
Could you please tell us why you want to have this with hole_making?
Best wishes,
Joachim
In production NX 12.0.1.7 D2
In testing NX 12.0.1.7 MP4
