Drive profile Fixed Tool Axis - Contour Bottom
I would like to drive(side of endmill) a closed profile using a surface (cylinder) as the part surface to control the bottom of the cutter, instead of a plane. Which milling method should I use?
Thanks.
Cyl
3 REPLIES 3
Re: Drive profile Fixed Tool Axis - Contour Bottom
Use fixed axis surface contouring operation.
Drive method: boundary ( your closed profile)
Part: the cilindrical surface
Projection vector: Tool Axis or  Specify Vector
If this is not what you are trying to achieve, please provide more information/example.
ciao
Luciano
Have you tried Solid Profile 3D if you want to run on 3 axis machine ?
Mak
I did not get a chance to try 'Solid Profile 3D'.  I ended up staying in 'Mill_Planer'.
and using a canted plane approximated thru 3 points that is close enough to the
cylinder at the profile.
Thanks you for the suggestions.
Cyl
