ERROR CAM
HOW TO CORRECT THIS PROBLEM?
Re: ERROR CAM
Analysis -> Examine Geometry
set all checks
select solid body
click Examine Geometry
Highlight results
Fix geometry that fails
If it is imported geometry
File -> Export -> Heal Geometry
  Or
Synchronous Modeling -> Optimize Face
Will sometimes cleanup bad geometry
Re: ERROR CAM
For examine geometry always select all entities of a body: body, faces, edges, etc.
It is best to use the rectangle selection method and hover the rectangle over the entire body, which will select every object.
The checks are always only done on the particular geometry, so if there are no faces selected, there are no face checks done for example.
