Edit Sim15 D Metacode
Hello all,
I would like to modify (or at least view) the Sim15 "D" Metacode.  I believe however that there is no D code anymore and the MCF refers to the 840d.CCF file.  When I change my machine configurator source to Siemens840d.CCF, the "edit metacode" box is grayed out.  How can I view/edit this information?  I can create my own D address in the .MCF, but I would like to use the OOTB as a reference.
I have the machine configurator advanced license, but I am clearly new to it.
Jeff
Re: Edit Sim15 D Metacode
Hi Jeff,
in such cases it is needed to select as Source the CCF and then copy the meta code into the current MCF file.
Thomas Schulz
Siemens PLM
Thanks Tom.
For others, I also struggled with how to "copy".  The method is to right click the address, etc. of what you want to copy and click "copy to current file".  I was trying to open it and copy the XML code which you can't do in the CCF.  Dumb mistake.
Jeff
