Enhancement requests for MRL
I have filed some enhancement requests for MRL, which might be of use to other companies.
You may ask GTAC to be attached to the case if you also think these are of use.
The case numbers are:
  1. ER#7300861 - tool assemblies must inherit NX tool type from cutting component
  2. ER#7298544 - milling and drilling holder component class miss NX holder section attributes
4 REPLIES 4
Re: Enhancement requests for MRL
Master
Master
The second ER is this related to having Vericut be able to bring tools to your project?
Shags72 Mfg. Eng.
Windows 10 Pro 64bit
NX 11.0.2.7 MP2 Teamcenter 11
Dell M7720 i7-6820HQ 16GB RAM,
NVIDIA Quadro P3000
I don't think that VERICUT will ever directly connect to Teamcenter MRL.
The NX to VERICUT interface from CGTech is able to create a tool library file with the tools used in the NX part, which is making more sense than having access to every tool in your NX database.
I was in a hurry yesterday, so I think it would be better to have separate threads for the enhancements to recruit other customers, if they see benefit of these enhancements.
Master
Master
I have tried the interface but the only thing I get as far as tools goes is say a drill that is the correct diameter but gage length long. Just a long skinny drill. I don't know how through the interface to get the holder to show up.
Shags72 Mfg. Eng.
NVIDIA Quadro P3000
What VERICUT release are you using?
Have you checked with CGTech support or CSR?
They are very friendly and you usually get a solution or response within a day.
