Error Authoring PDF Work Instructions
Anyone with some experience authoring work instructions? I'm attempting to export to PDF but I get the following error:
syslog says:
**** Work Instructions error ****
There was a problem executing the PDF converter.
Please check that the converter software is installed in the default location:
C:\Program Files\wkhtmltopdf\bin\wkhtmltopdf.exe
Re: Error Authoring PDF Work Instructions
Hello @Sup3rscript3d
You need install wkhtmltopdf tool.
You can find the file to download and install in the link below.
https://wkhtmltopdf.org/downloads.html
I hope it helps.
Jean Marcel
Application Engineer
Ally PLM Solutions | PROLIM PLM
