Error No 830001, I am facing this error while loading an assembly file in NX.
Hi
 I have made an assembly file in which i had done a lot of CAM works by spending 2 days.
It saved successfuly but now at the time of loading it is giving an error
"Could not open(file path)
error no 830001
the following file could not open causes this open to fail(again path of the same file)
Above , between the braces it is the path of assembly file which i have created.
As this problem is occured in my official pc therefore i cann't provide here any additional detail i.e sceen shots ,.prt file.
Here i must tell you that i am using NX 12.
I just want to ask from you guys that what is error 830001? Also tell me please is it any alternative way to open this file?
4 REPLIES 4
Re: Error No 830001, I am facing this error while loading an assembly file in NX.
Can you at least provide a log file? If we get that to the developers then we have a shot at seeing where the problem is.
There is a MP01 out for 12. Lots of these types of errors in the fix list.
{Paul Schneider}, {CNC Programmer}, {DRT-Rochester}
Production: {NX11.0.2,MP5, NX12.0.2, MP4}
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/ERROR-OPENING-PRT-DRAFT-FILE/td-p/44...
Install MP01 and this problem is fixed.
Kurt Neubaecker
CAD/CAM Designer
Proficient Industries
Cleveland, Ohio
Any one solved this error please let me know.
