Error opening sample machine posts
Is anyone else having an issue trying to open the sample simulation fanuc posts? I keep getting an error trying to open the sim08 fanuc post as well as others.
Here is the error for sim08:
NX 10.0.2 PB 10.0.2
Re: Error opening sample machine posts
I just tried in PB 10.0.3 - no problem there.
This post from the library machine was updated.
Try the attached.
Mark Rief
Retired Siemens
This error happens for me too. I noticed that the mm one opens ok. Did a compare and in the tcl - the metric post has this:
if { [llength [info commands $ude_handler]] &&\
![llength [info commands ugpost_${ude_handler}]] } {
rename $ude_handler ugpost_${ude_handler}
and the inch one has:
if [llength [info commands $ude_handler]] {
which explains the error. I would report it to GTAC. You can also edit the file under postbuilder.
NX10.03
Windows 7 Pro
No need to report to GTAC - it is already fixed in 10.0.3.
Mark Rief
Retired Siemens
Thanks guys!
Mark,
I couldnt use your files because they were created in a newer version of post builder.
Study,
I copied the lines you were showing in the tcl from the mm post to the in post and it works now.
Thanks!!
NX 10.0.2 PB 10.0.2
JasonP wrote:
Thanks guys!
Mark,
Oops! Forgot about that ...
Glad you got things working.
Mark Rief
Retired Siemens
