Error while opening post builder.exe file
I am facing an issue while opening Post_buil.exe file from my siemens directory. As i attached two snaps of this.
Please tell me how to resolve this issue. If  you know  any other way to start post builder then share me this also.
Re: Error while opening post builder.exe file
Never start a NX executable directly from Explorer, since they need a specified environment.
Most of the short cuts contained in the start menu are launching a batch file that sets the correct environment to run the utility.
So always start NX applications from the start menu or a copy of the start menu entry.
Thanks for replying @Stefan_Pendl .I tried to opened it from Start menu but it returned with the erorr(Snap1).
"Cant find a useable init.tcl in the following directories".icopied Init.tcl files in some of required directories now error msg is disappeared but post builder doesn't proceed further and hanged on by displaying black cmd screen.(Snap2)Capture1.JPGCapture2.JPG
I would say that your NX installation is broken and should be reinstalled to fix it.
Have you disabled your anti virus software during the installation of NX, if not you should do so, especially if you use anything else than Windows defender.
