Export feature in machining machining data library?
How can I export the machining database in my computer to another one?
Re: Export feature in machining machining data library?
If there are running the same NX version and customization, you can copy the data files:
cut_methods.dat
feeds_speeds.dat
machining_data.dat
part_materials.dat
tool_machining_data.dat
tool_materials.dat
Mark Rief
Retired Siemens
Thanks! I have solved problem.
