Export of point and vector data
For laser drilling and shaping of cooling holes DMG requires XYZ point location and YJK vector data for programming purposes.  Does anyone know of a simple way to export this data.
3 REPLIES 3
Re: Export of point and vector data
I did a same for Wood (I forget exact name of software, need to check it). Ugopen application, for all cylindrical faces output xyz for center point and ijk for tool axis. Later I did a same for riveting machine.
I remember, it was WoodWop software for woodworking CNC Macine. Exact your problem, I recognize all cylindrical holes and output xyz for center and ijk vector for tool axis.. See a video.
Or - you can insert few point-to-point CAM operations with defined tool axis for each point and output as CLS, each line will be
GOTO/X,Y,Z,I,J,K
as you need..
Create a 5 axis drilling program, and outout a CLS file.
Mark Rief
Retired Siemens
Thanks Guys that will work.
