FBM THREAD MILL
I am trying to implement FBM in my company. I have succeed with some operations but with some others I am having troubles.
Have anyone used the Thread Mill operation? Every time I use it, it creates the operation but also shows this message:
[F_14]-STEP1POCKET_THREAD -->> [F_16]-STEP1POCKET_THREAD (double node,
identical features)
No solution found for the following features:
feature.STEP1POCKET_THREAD (STEP1POCKET_THREAD) : extId
Tue_May_17_11_20_35_2016_9284_1000023, af_id -999
9, instant 16 (parent = none, pbl )
MACHINING_RULE (MACHINING_RULE): == THREAD_MILLING_STEP1POCKET_THREAD
X_ORIENTATION_D == -0.0000
X_ORIENTATION_L == 1.0000
X_POSITION == -50.0000
This is a picture of the code.
Can anyone help to understand what is happening with my code?
Salvador
Salvador Peregrina
Manufacturing Team Leader| NX 11.0.2.7
Re: FBM THREAD MILL
The problem is that you don't have any application criteria, that will hinder the system to execute the rule once more.
I would add the following application criteria to the rule.
mwf.MACHINING_RULE <> "THREAD_MILLING_STEP1POCKET_THREAD"
This will make sure that the rule is only executed once for each threaded hole.
Re: FBM THREAD MILL
Hello Stefan,
I just tried and it worked! I will try to look into detail for what the "Machining Rules" are used in order to make a better/clean code.
Thank you for your information.
Salvador
Salvador Peregrina
Re: FBM THREAD MILL
I just noticed that you used the machining rule in the LWF section of the conditions, so I suggested to use that as an indication, that there is no more threading needed.
The machining rule attribute can be used for anything you like, it is just a flag variable with no dedicated usage.
Re: FBM THREAD MILL
Generally there are two ways of handling the machining feature process rules:
  1. let more and less worked features always be the same
  2. more and less worked features are always different
Way 1. allows to specify a dedicated process for each feature, but needed flag attributes to control the flow of the process.
Way 2. allows reuse of code, since after a thread has been machined, the previous feature is without a thread.
From my point of view a mixture of both is now best starting with NX 9 and using the new drilling operations and the machining areas (FACES_CYLINDER_n) Smiley Wink
Re: FBM THREAD MILL
Thanks for the explication!
In the manual of Siemens there are only two pages in which this is explained. Any complementary knowledge related to the topic is more than welcome jejejeje
Salvador Peregrina
Re: FBM THREAD MILL
Hello Stefan,
Sorry for bothering again, but I am stuck trying to link different codes from a Blank to a Step2Hole.
Do you have an example of how to link the codes?
Thanks in advance!
Salvador Peregrina
Re: FBM THREAD MILL
Can you post what you have so far, since there is no general way of creating the rules for FBM.
Re: FBM THREAD MILL
Hello Stefan,
Ok this is a picture of my library. The main problem I am having is when there are subsecuent operations:
1st   Operation - Pre Drill
2nd  Operation - Mill Rough
3rd   Operation - Mill Finish
4th   Operation - Thread
5th   Operation - Chamfer
So far,I am using comments and priorities to stablish a correct operation secuence. The reason of my question, is because I have not found a logicall method to do it and maybe there is a better one.
Salvador Peregrina
Re: FBM THREAD MILL
Generally the last operation should have the highest priority.
Example:
  1. Mill finish .... priority 100
  2. Mill rough ... priority 50
  3. Drill ............. priority 10
The comment will then show the action already taken.
Example ( first is always application criteria, second is always LWF value handed forward ):
  1. Mill finish
    • NOT is_defined(mwf.comment) OR mwf.comment = ""
    • lwf.comment = "MILL_F"
  2. Mill rough
    • is_defined(mwf.comment) AND mwf.comment = "MILL_F"
    • lwf.comment = "MILL_R"
  3. Drill
    • NOT is_defined(mwf.comment) OR mwf.comment = "MILL_R"
    • lwf.comment = "DRILL"
You just have to keep in mind that the system searches from the most worked feature (mwf) to the less worked feature (lwf).
