FBM hole_making.DRILLING cycle Drill,Deep Step
Hello there,
I am working on a hole_making.DRILLING operation. Its cycle type is Drill,Deep. In NX, when I edit the cycle parameters, I can find a "Step" parameter in the dialog, but I cannot find such an Add-on in MKE.
Kai
NX 10.0.3.5
Re: FBM hole_making.DRILLING cycle Drill,Deep Step
Hi Kai,
You will need to define an Add-on of type Depth_Increment.
That should do the trick.
Tom van 't Erve
NX CAM Development
