FBM: hole_making.TAPPING - how to set thread form to from table
If the thread is not designed then we need to set the thread information from the table, see image below.
How can this be done through MKE and the FBM rules?
I have already checked every setting, but found nothing.
I have found nothing to set "From Model" to "From Table", thanks in advance for any pointers.ThreadFromTable.PNGThread Feature
Re: FBM: hole_making.TAPPING - how to set thread form to from table
From Table is not the best practice for this use case. Use From Model with the desired tapping tool instead. The tool wins and defines the thread parameters.
Best wishes,
Joachim
In production NX 12.0.1.7 MP4
In testing NX 12.0.2.9 MP5
The tapping tool and the drilled hole match the thread definition, but there are still gouges reported.
If I change to the correct thread from the table, then the gouges are no longer reported.
Disabling gouge checking is not an option, since this is used in a process that doesn't support interactive actions.
Doesn't the authorized gouge mechanism prevent you from having an issue with the gouge? The tool with thread depth defines the in-process volume. If NX still reports gouges, then there is an incident and what you want to do is really a workaround.
Have you tried operation teaching to check if NX recognizes this parameter?
Best wishes,
Joachim
As mentioned before the symbolic thread is not designed as it is with STEP imports and similar.
I have reported this to GTAC now and it seems that NX 11.0 behaves differently from NX 10.0.
Still, to make sure this doesn't brake anything in the future, setting the correct thread definition from the table would be much appreciated.
