FBM pocket enhancements
Starting with NX 11.0.2 MP6 some enhancements to pockets and their recognition have been added.
  1. Newly added pocket types
    • POCKET_OPEN
    • POCKET_CLOSED
  2. Separate machining areas
    • FACES_FLOOR
    • FACES_BOTTOM_RADIUS
    • FACES_WALL
    • FACES_TOP_CHAMFER
    • FACES_CYLINDER_1 (2,3,4)
  3. New attributes for wall draft angle
    • MIN_SIDE_ANGLE
    • MAX_SIDE_ANGLE
  4. New attribute for top chamfer angle
    • ANGLE_TOP_CHAMFER
The two new pocket types allow recognition of pockets with walls that have draft angles applied.
Most of the pocket types now support recognition of a top chamfer.
The milling areas are no longer only separated into floor and wall, which allows one to use their own combination of machining areas. Creating a GeometryParent add-on of type mill_planar.MILL_AREA one could use the following settings:
gp.Wall_Geometry = mwf.FACES_TOP_CHAMFER + mwf.FACES_WALL + mwf.FACES_BOTTOM_RADIUS
gp.Cut_Area_Geometry = mwf.FACES_FLOOR
Enjoy these new enhancements Smiley Wink
Re: FBM pocket enhancements
These two pocket types are now also available in NX 12.0.2 MP2, so happy pocket machining.
