FLOW CUT TOOL PATH
Can anybody tell why the tool path curls at the start point while using different dia tool Flow cut operation. Pls find below jpeg filesWHY THE TOOL PATH CURLES AT CORNER.jpgIT SHOULD B LIKE THIS.jpg
GIGY JOSE
MOLD DESIGNER
PIRAMAL GLASS LTD
4 REPLIES 4
Re: FLOW CUT TOOL PATH
In the cutting parameters is roll over edge enabled?
Which faces are in the cut area? If the cut area is only the faces you want ot cut, it should not roll over.
You can also limit what happens at the edge of the cut area with the setting Cutting > Containment > Uncut Corners > Find Corners > Within Cut Area.
If this does not solve it, please post a picture with higher resolution, and geometry highlighted.
Mark Rief
Retired Siemens
Roll over is not enabled.
You can see  the second jpeg file the tool path is not curled, only difference in both the tool paths is the tool dia used
GIGY JOSE
MOLD DESIGNER
PIRAMAL GLASS LTD
Thanks Mark
I will try out .
GIGY JOSE
MOLD DESIGNER
PIRAMAL GLASS LTD
