Face Milling
Hello
I Have a question...
If i create a face milling operation with Zig-Zag toolpath, the toolpath retracts on every cutting depth.
Is there an option to cut backward?
Generated path:
Edited path:
Thank you
Production: {NX 10.0.3.5 MP18}
Testing: {NX 12.0.2.9 MP03}
5 REPLIES 5
Re: Face Milling
I think - it impossible for facemilling operation. You can use Sequential Milling, not so easy, but..
Re: Face Milling
Okey thank you.
I asked because the first cam i've used was Mastercam 9.1 and there was a button to set the toolpath after stepdown backword.
The searching for this button has endet Smiley Wink
Re: Face Milling
How to do this edition?
Re: Face Milling
In the tool path editor, set the selection to cut level, select a level, and reverse it.
Mark Rief
Retired Siemens
Re: Face Milling
I could not do Can you make a video to help me?
