Feature Mapping - Adding Machining Areas
is it possible to add machining areas to mapped features ?
I cann add in the customization new areas as attributes, but is it possible to add
assign geometric elements to the attribute ?
NX 11.0.1.11
Re: Feature Mapping - Adding Machining Areas
See the section feature machining areas in the NX documentation.
Generally you create a PMI note that references all faces to be included in the area before you teach the feature.
