File Import successfully but store shows up Internal error. - by using "Guiding Curve"
Hi everyone,
When my Drive Method choose "Guiding Curve" I can't store my file after I import this file.
Problem description:
I use this Operation "Fixed_Guiding_Curves".
Inside the dialogue, Drive Method choose "Guiding Curve".
After that, generate the path and store the file.
But after I import this file and want to store it, it shows up "internal error" and doesn't allow me to store.
Question :
Why Drive method to choose "Guiding Curve" can't let another new file store after using "import" way?
Thanks for your time.
3 REPLIES 3
Re: File Import successfully but store shows up Internal error. - by using "Guiding Curve"
Please contact GTAC and create an Incident Report on this case.
Thanks for your reply, I'll connect GTAC。
Hi everyone.
Let me report the progress of this issue.
GTAC's reply is as follows:
