File mom_information.out
Builder
Builder
Hello, after every postprocesing system create with .mpf file with name mom_information.out.
What it is? It is possible to disable?
NX 9.0.3 MP05
Re: File mom_information.out
Siemens Legend Siemens Legend
Siemens Legend
The easiest way is to edit the configuration file that you are using (in the ...\MACH\resource\configuration folder) and comment the line that starts with "WIZARD" with a "##".
This goes with the assumption that you are not using the "Process Assistants" with NX CAM.
If you do, than more actions are required.
Success!
Gerrit Koelewijn
The file usually contains the error message that triggers its creation, resolve the issue and you will not get it anymore.
