Fix for PB 10 - PB10.0 SFB 08Dec2014 msgs.7z
Hello everyone,
I'm trying to fix PB 10 error where it shows
can't read "gPB(menu_index,file,property)": no such element in array
I found some solutions on the forums which point to a file 'PB10.0 SFB 08Dec2014 msgs.7z'.
Its also on solution center. The link given in the solution is
https://download.industrysoftware.automation.siemens.com/unigraphics/cam/
Now, whenever I open the link and go to customer folder to download the file, it says file not found.
Is it moved, deleted, or what?
Any help would be appreciated.
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
Re: Fix for PB 10 - PB10.0 SFB 08Dec2014 msgs.7z
Can someone just give me a link or something from where I can download the file (in case it's available somewhere else).
NX 12.0.2
Solid Edge 2019
You should update NX to 10.0.3 than this problem is solved
Restored from an old backup Smiley Wink
@CWilson
Thank you very much!
You literally just saved the internet haha.
NX 12.0.2
Solid Edge 2019
@schauerm3
I am aware that updating NX to 10.0.3 or just 11 directly will fix this problem, but I just wanted to fix it up on the current version itself.
In any case, thanks for the suggestion.
NX 12.0.2
Solid Edge 2019
