Floor Wall stock not working
I just noticed that the operation Floor / Wall ignors the stock default from the method.  It adds the stock from the method into the box " part stock "  .  i do not see a check box that says use same floor and wall.  is there another setting im not seeing?  the tool path did not offset by the .030 in the part stock and nearly scraped a part.  I movede the .030 into the wall stock and it worked just fine.
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
Re: Floor Wall stock not working
This is how floor wall works.
There is an enhancement in the backlog to align the stock inheritance with cavity mill.
Mark Rief
Retired Siemens
