Flowcut Cut Regions
Builder
Builder
Good day,
I want to ask if it is possible to hide flowcut region leaders (cut region numbering),
because it always blocking the views when reviewing the areas to modify or
looking the flowcut output regions.
Thank you,
Jayson
Re: Flowcut Cut Regions
Hi Jayson,
You can press F3 once to hide cut region numbering.
If you press F3 second time the dialog box will hide and, if you press F3 third time, all (cut regions numbering and dialog box) will show again.
I hope this help.
Jean Marcel
PLMPRO
www.plmpro.com.br
Builder
Builder
Hi Jean Marcel,
Thank you to your reply.
I did press the F3 button and the cut regions did not hide, but this activate the rotate command.
I did not do any customization on my keyboards command.
Is there any other way?
Thank you again,
Jayson
Hi Jayson,
The default keyboard for rotate command is F7.
You can check for what keyboard is in use for UG_VIEW_CURRENT_DIALOG and use this keyboard or reconfigure this for F3.
I hope this help.
Jean Marcel
PLMPRO
www.plmpro.com.br
Builder
Builder
Hi Jean,
Good day,
Sorry for my previous reply, I did saome configuration before but I did not check
it before replying to you.
Now it works prefectly fine.
Thank you very much,
Jayson
