Flowcut issues
Notice geometry, there are two sets of half-circles - 4,5,6,5 mm diameter.
One set has blend on sharp edges.
I simply create operation with flow cut reference tool and generate.
Tool D5, reference tool D8.
First operation (original) result:
Second operation result (only change to steep pattern Z-zig, step 1mm):
Additional question for this pikes:
Please take a look.
Try to do something and even blended geometry sometimes gives wrong result.
Somewhere steep/nonsteep areas are missing/consuming - not recongnized, etc.
Is there any setting to avoid this?
Or should I send it to GTAC?
Thank you.
Re: Flowcut issues
Hello Juraj,
would you mind contacting GTAC, so we can investigate this case?
Thank you in advance
Alexander
