Flowcut
When using flowcut, before the tool engages the part and after it retracts from the part there are long
plung and lift cuts
 How do I shorten or get rid of those lengths
Re: Flowcut
it would be better if you attach part or picture to let us know more about situation. Now we can only guess.
But you can try to set smaller or zero values for clearances (Cutting Parameters -> Clearances). These values can cause that engage or retract moves are longer, especialy if the tool is close to shape (if it is not cause by non cutting moves settings)
Vavrusa Ondrej
NX10.0.3
NX11.0.x testing
Re: Flowcut
Gears Legend Gears Legend
Gears Legend
Probably caused by the collision check under non-cutting moves > more... > Collision check.
Patrick Delisse
KMWE - Aero Engine
NX 12.0, TC 11.2, CAMPOST V22, Vericut 8.2, TDM 4.8
C#, VB, .NET
Re: Flowcut
Paehv,
Perfect just what I was looking for
Nothing in this message is intended to constitute an electronic signature unless a specific statement to the contrary is included in this message.
Confidentiality Note: This message is intended only for the person or entity to which it is addressed. It may contain confidential and/or privileged material. Any review, transmission, dissemination or other use, or taking of any action in reliance upon this message by persons or entities other than the intended recipient is prohibited and may be unlawful. If you received this message in error, please contact the sender and delete it from your computer.
