Force Cavity Mill / Operations to Stay inside of Machine travel limits?
Is there an easy way to do this?
I have 2 smaller (400mm) 5 axis machines and I'm always fighting cavity mill to stay inside my Y travel limits when tilted over at a-90.
Dennis Rathi
Creations Unlimited
Re: Force Cavity Mill / Operations to Stay inside of Machine travel limits?
Trim boundaries seem to be ignored by Engage/retract.
Dennis Rathi
Creations Unlimited
Hi Dstryr,
You can reconfigure machine tool travel limits with NX postbuilder.
That will force Cavity mill in NX to stay within certain areas?
Dennis Rathi
Creations Unlimited
Could be not sure without seen it.
Which NX release?
Starting with NX 8 or 8.5 many operations offer to force engage to be kept inside the trimming boundary.
Machine limits won't be recognized until you simulate.
If you want Cavity milling to avoid the limits when the path is generated, I agree a trim boundary is good. You could define a rectangle at the limits and set the custom stock to a little more than your longest engage length.
If you to use it for several operation, put it in a mill area geometry group, under the workpiece.
Mark Rief
Retired Siemens
