Gap with previous member closed
When I want to select curve for trim boundaries. I meet one alarm message called" Gap with previous member closed".I know maybe two curve is not connected. but how to fix this with command!
Thanks!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
UG_NX is my favorite !!!!!!
Re: Gap with previous member closed
I think this is due to the two members not intersecting in space at all, so you can just ignore it.
Trim boundaries are always closed.
I think the message is just telling you that the system will close the gap.
The message type is "Warning" with the yellow triangle, which means you can continue.
Mark Rief
Retired Siemens
After selected trim boundaries. Still alarm message come out. Why?
UG3.0
UG6.0
NX10.0.35
NX11.0.1
In your case I would not select so many elements, less elements are more likely to not self-intersect.
You only have to make sure the extension of the elements crosses the one of the following element.
