Grooving Again!
I'm trying to find the switch in the Grooving Routine where I control the clearance plane.
The tool is backing up too far and would like to control this. The feedrate is too slow for too
long on the approach.
I'm not sure if it's found in CUTTING PATAMETERS or NON CUTTING MOVES? Looked everywhere?
Using NX 11.0.2.7
Please see attached graphic.
Cyl
Re: Grooving Again!
Try Non Cutting Moves > Engage Tab > Plunge Group > Safe Distance.
LMGi
www.TLMGi.com
Re: Grooving Again!
THANK YOU!!
