Guiding Curves
Siemens Legend Siemens Legend
Siemens Legend
Hi
Guiding Curves is a major area of investment as a modern way to generate and control finishing toolpath especially when using Multi Axis. if you have not tried it - please do as it will cover more and more use cases. if you did - we are looking for your feedback. i.e.:
  • where did you try it and found it useful
  • where it was lacking capabilities / generated unexpected results
  • Are you missing usage instructions? high level (what is it good for) / low level (how do I control XYZ)
etc. any feedback is welcomeSmiley Happy
Yours,
Eddy Finaro
NX CAM Product Manager
Siemens PLM
37 REPLIES 37
Re: Guiding Curves
so, from my point of view guiding curves is an operation
what I have thought about long time ago would be good to exists:
-> patter that you can control its shape / from geometry, other curves
-> spiral, helical patterns / without retract,engage
-> 5axis operation with smart tilting
Good move.
At the moment what is not so good in this operation is the time od generating, compared to streamline.
What about on/tanto/contact?
Re: Guiding Curves
Siemens Legend
Performance went throgh some major improvements. in recent EAP and 12.0.2 it is much faster than before.
it is not as fast as streamline especially if the streamline path is generated on the drive (i.e no part or cut area), but it is way more robust.
it always work with Contact / Tanto. on is not planned (as it not really control the finish results)
Yours,
Eddy Finaro
Siemens PLM
Re: Guiding Curves
Ive been using EAP package and this operation has replaced my usage for streamline. This path is more reliable and gives way better toolpath result (IE no funky streamline spiking)
Only improvement I look forward to is the addition of interpolate vector for tool axis.
Dennis Rathi
Creations Unlimited
Re: Guiding Curves
Siemens Legend
==> Only improvement I look forward to is the addition of interpolate vector for tool axis.
it's comming..Smiley Happy
Eddy Finaro
Siemens PLM
Re: Guiding Curves
In my testing it hangs up 33% and doesn't generate anything at all. I will test on some different models soon.
Edit:
If i waited a few more minutes, I found it finished generating, but had a lot of gouges. PR 9189494 was created. It seems that when Avoidance is set to "none" that it can still gouge the model. When I used the "Tilt/Retract" or "retract" by itself, it would not gouge. If using  "avoidance > none" verify your path carefully.
Dear Customer,
Reference: PR Number 9189494
Siemens PLM believes that the problem you reported where the documentation for
the VARIABLE_AXIS_GUIDING_CURVES operation is incomplete will be resolved by
code changes made to the release of our product NX version 1847.
Glenn Balon
Production: NX 12.0.2 MP5 Primarily CAM
Re: Guiding Curves
Siemens Legend
Can you please open an IR for the case that hangs? not fun, but we need it to improve..
Eddy Finaro
Siemens PLM
Re: Guiding Curves
Will do. I will confirm its not something I am doing wrong 1st though.
It would get to 33 out of 100, sometimes 34, then sit for a few minutes. After more than 4-5 min of waiting I usually kill the session.
Glenn Balon
Re: Guiding Curves
Siemens Legend
Glenn - NX 12.0.2 and later in 1847 performance gets way better. if you do not have access to EAP versions and can upload the prt - I can tell you how the system does today. 12.0.2 will be released in less than a month.
FYI,
Eddy Finaro
Siemens PLM
Re: Guiding Curves
Hello, I'm just getting to know the variable guiding curve. Very manageable operation.
Do I have a question:
What the containment loops are?
Will it be a 3 axis operation?
Below is the video from the first 5axis guiding curve with fixed axis and avoidance and axis smoothing:
(view in My Videos)
Have a nice day
Vladimir Jesensky, CAM, TFM Slovakia
Production: (NX 12.0.02 mp05)
Testing:(EAP1872)
Time is money
