Re: Guiding Curves
Is it possible to select a closed loop as a Guiding curve? I get a path if I select only a few of the outside curves, But no path if the entire periphery is selected.
I am still on NX 12.0.1.7 MP1
Glenn Balon
Production: NX 12.0.2 MP5 Primarily CAM
Re: Guiding Curves
Siemens Legend Siemens Legend
Siemens Legend
sure close loop is a very legitimate input!
in this case you selected to cut only on the right side of the curve. try both it might resolve the issue. In this case please open a PR since it should have worked.
Yours,
Eddy
Eddy Finaro
NX CAM Product Manager
Siemens PLM
Re: Guiding Curves
I tried all options, I'll open PR.
Edit: The "Both" option worked, but wouldn't the "Right" be the face that is to the right of the guide, looking in same direction as guide?
Glenn Balon
847-494-5366
Glenn Balon
Re: Guiding Curves
Siemens Legend
Yes it is. This is why I sugested to open the PR.
Yours
Eddy
Eddy Finaro
Siemens PLM
Re: Guiding Curves
Hi Eddy,
will it be possible in future to use also torical cutters? This would be really helpful because I really often have to make programs for surfaces where I´ve to control the cutting sequence of the toolpath. And with stream line htis is not possible.
Thanks and best regards!
Re: Guiding Curves
What is torical cutter? Can you show a picture example. Did you mean toroidal?
Glenn Balon
Re: Guiding Curves
Sorry, I mean an end mill with corner radius Smiley Wink
Re: Guiding Curves
Yes, the team from Eddy Finaro will start to enable that feature during the next months. It should be available for testing at the beginning of next year.
We will definitely enable this tooltype and already think about others as well (Tangent Barrel). So step by step we will work on your requirements :-)
We are very glad to see you all like Guiding Curves!
Lead Product Manager - Mold & Die
