HOLE 5 AXIS
PLACING M00 IN THE HOLE WITH INTERRUPTION TO CLEAN TOOL
5 AXIS
Re: HOLE 5 AXIS
Can you post a picture of what you are trying to do?
Mill? Lathe?
With a cycle?
There are several tech tips on drilling interrupted holes, maybe this is covered in one of them.
Mark Rief
Retired Siemens
Re: HOLE 5 AXIS
1. Set incremental DRILLING with breakchip:
For your case I set:
M0_3.pngVariable Step
Geneate toolpath
3. Edit toolpath. After each step insert Stop UDE:
You can remove next up-motion or keep it
