HORIZONTAL 5 AXIS FANUC TABLE B AND TABLE C MACHINE MODEL
Can you suggest which OOTB machine simulation model can be used for 4 axis HMC upgraded to 5 axis 3+2 machine with installed rotary table C?
Mirko
Re: HORIZONTAL 5 AXIS FANUC TABLE B AND TABLE C MACHINE MODEL
I like to help, but may I misunderstood.
How many axes has your machine tool? I Assume 5 but you mentioned 4 axis HMC
HMC --> Horizontal Mill Center ?
At the end we do have multiple 5 axis machine tools.  Here an overview
Thomas Schulz
Siemens PLM
It is 5 axis machine Horizontal Machining Center with
X,Y,Z, B and C axis. it is not full 5 axis continous, only 3+2 positioning, Fanuc 31i
thank you
