HOW TO FIND ENHANCEMENT REQUEST STATUS?
Inquiring about ER 6906821
EDS UG V3 -UG V15 UNIX; UGS UG V6 -UG V19 - NX-NX5 UNIX/MS; Siemens NX6-NX11 MS
Re: HOW TO FIND ENHANCEMENT REQUEST STATUS?
You can only see the status of your own ERs.
You would need to be added to the ER by GTAC to get information on when it is added.
The status of any of your IRs, ERs and PRs can be seen at the GTAC web site through the IR tool search.
Thank you Stefan for the info.
 I have tried this and have had no success with the IR search.
I didn't know if Siemens had changed there policy.
You can only access your calls, this seems to be a call from a Siemens employee, so you can only try to get linked to it to get notified when it is implemented.
Due to privacy policy there is no way to follow any call of another company.
Yes, I filled out IR and it was converted to ER it was the way things were done back then.
No worries, thank you for your help.
@59holloman I checked, and this is indeed your ER, so you should be able to get the status online. If not, you can call GTAC and they can look it up for you.
In this case, it is "unscheduled", which means Product Management agrees it is a good enhancement, but it has not been scheduled for development. As you can imagine, the priority is based on many factors.
Mark Rief
Retired Siemens
Thank you Mr. Reif for the help & update.
