HOW TO GET RID OF CAM PERMANENT TOOL DISPLAY IN LAYERS
I am making seedfile for manufacturing template, so i copied my previous mfg file and deleted all components and tool path but in layers still it's showing permanent tool display how to get rid of them in layers
Ganesh
NX 8.5 and Vericut 7.3
Re: HOW TO GET RID OF CAM PERMANENT TOOL DISPLAY IN LAYERS
Esteemed Contributor
Part cleanup => clean CAM objects?
I did the same but still I have those in my file
Ganesh
Which NX release?
Would be good if you create a signature similar to mine where your environment is listed, so we don't have to ask for it every time Smiley Wink
I am using NX8.5
Ganesh
There have been issues with tool display objects being left behind, but these should have been resolved in NX 8.5.3.
Which NX release are you using exactly?
Exact release is NX 8.5.2.3 and here I am attaching test part which after part clean up still cam display in layers
Ganesh
Ganesh,
I just ran part cleanup in 9.0.3 and it removed all of them - see attached.
So whatever they are, we updated part cleanup at some time to take care of them.
Mark Rief
Retired Siemens
Could you please share the snap shot of part cleanup window for which options you selected. I am using 8.5.2.3 I tried all the options. Might be needs to apply some tricks.
Also there is entity called user defined in layers what's this and how to take off that
Ganesh
It is not possible to get rid of the entries in NX 8.5, you must upgrade to NX 9.0.3 at least.
