Has anyone offset 3D surface contouring milling toolpath with an 840D Seimens controller , please.
4 REPLIES 4
Re: Has anyone offset 3D surface contouring milling toolpath with an 840D Seimens controller , pleas
Which Siemens types of cutter comp did you want to support?
CUT3DC?
CUT3DFS?
CUT3DFF?
CUT3DF?
something else?
I created  a variable axis surface contouring path with a ball mill and contact output, added the Siemens UDE at the beginning, and posted through the out of the box mill_5axis_actt_Sinumerik_840D_mm post, and got CUT3DF output. Is this what you are asking about?
Mark Rief
Retired Siemens
Hi Ken,
Sorry for the delayed response.
After looking at the Siemens 840D documentation it may be a combination of that we’d use for  5-axis surface machining.
CUT3DC Compensation perpendicular to path tangent and tool orientation
CUT3DF 5-axis with variable tool orientation
CUT3DCC NC program relates to the contour on the machining surface.
I am good for now and appreciate your Help.
Thanks C Foshey
Hi Mark,
I’ll look at applying the Siemens UDE’s to 5 axis surface machining and I appreciate your help,
Good to hear from you,
Thanks C Foshey
