Helix motion
Builder
Builder
Hello, how add helix move to my postprocessor? I import custom command "pb_cmd_helix.tcl", but it isn´t show under "Toolpath / Motion".
Thanks.
12 REPLIES 12
Re: Helix motion
Which PB release or NX release respectively?
Some things that you import are not listed in the motion sections, you can only access them from the custom commands section.
Re: Helix motion
Builder
Builder
NX 11.0.2 MP04
Re: Helix motion
From the solution center it seems that there is only the way through the custom commands section.
Re: Helix motion
open the PostProcessor file .PUI in the text editor and add the {Helix Move} line in the #Motions section. After saving and opening the postprocessor in PB, Helix move appears.
Re: Helix motion
From the custom commands import the pb_cmd_helix
add the PB_CMD_init_helix to the start of program event
You should get Helical output  - read the header in the custom command about making any changes.
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
Re: Helix motion
Builder
Builder
Only method with manual edit pui file working for me (thank pajalin).
Re: Helix motion
I don't think manualy editing the .pui, .tcl or .def files is recommended.
You had initially posted an image from Post Builder
What is it your truly looking for?
Senior Aerospace
Re: Helix motion
Builder
Builder
In my postprocessor missing helix move motion. Output for helix operation (hole milling) is in linear mode. I'm looking for a way to add this motion.
Re: Helix motion
I think we have provided the techniques to add helical motion to a post.  If this does not work then I wold suggest contacting GTAC.
Senior Aerospace
