cancel
Help Needed in Multi-Task set-up
I am a user of NX8.5 mostly in manufacturing.
I am having difficulties in setting up a DMG/Mori CTX beta 1250 TC. The problem is that when I try to simulate a turning operation, the B-head is not indexing itself at 90 deg.
I have tried using other multi-task machines with a synchronised tool path and it works, but when I try do sync the toolpath with this machine it gives me a initialization error. The machine is a dual-spindle, b-head multi-task.
Also I am experienced difficulties at the start and end events.
There are a lot of RG type parameters (RG779; RG721, etc) that I do not quite understand. Is it possible to get some sort of list with these RG parameters explained ?
I have tried searching the internet for them, but I could not find them.
Could someone help me with my two problems ?
Thank you
