Help with editing the CSE driver
Hello everyone,
Would anyone be here to help me modify the CSE driver for the DMG MORI NZX2000? I used the CSE driver FANUC from OOTB sim15_millturn_9ax. I need to change the driver for two revolvers. One revolver at the top and the other down. In OOTB there is a head with B axis and it does not work.
thank you very much
