Hole milling with cutter compensation
In the holemilling I get the the message:
The requested minimum move or angle for cutter compensation could not be made safely.
Cutcom statements will not be output.
The cutcom is on but there is no finish pass?
With best regards,
Tom de Koning
Re: Hole milling with cutter compensation
The problem was the size of the minimum moves as shown in the attached images.
I would also enable output of contact data, since that is what a machine operator usually expects and what works best with most machine controls.
In addition you don't need helical engage, circular is enough, since you are already using helical cut pattern.
Production: NX12.0.2, VERICUT 8.2, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 11.4
Development: C (ITK), .NET, Tcl/Tk Testing: NX (1876) | AWC 3.4 Preparing: -
Stefan, thanks
Its works well
Tom
