Holemaking non_cutting collisions
How can I fix this collisions ?
Path should not be generated.
Collision checking for cutting and non-cutting moves are turned on.
Re: Holemaking non_cutting collisions
From your image, it seems that this is a collision in the Non Cutting Moves.
Check your Non Cutting Moves -> More -> Collision Check setting to make sure that Collisions Check for Non-Cutting is activated.
Tom van 't Erve
NX CAM Development
Yes, I wrote that it is. By default.
(attachment)
Only if there is a collision with flute it will not generate tool paths.
Would you mind uploading the part here? Or if it is restricted, you can contact GTAC and upload it there. Then we can have a look.
Thank you in advance
Lead Product Manager - Mold & Die
hi, I uploaded it, but I dont know why attachment is not visible, if I edit posts attachment exists...
I uploaded part several times and it is not visible
Please share the use case with GTAC and ask them to review this.
Tom van 't Erve
NX CAM Development
hi,
done
