Do you mean
Reply
Solved! Go to solution
How can I add some more attributes to the Shop Document Template? For example Material?
I have an issue in this part of my template, I can´t put any attribute from the mom_variables here, it just seems like has nothing to put here, how can I add more attributes in this area?
Look in the image below I put the same mom_variable but in diferent cells and see what happened, eny comment?
Solution
Solution
Accepted by NXManufacturing (Community Manager)
‎08-26-2015 04:32 AM
Currently, mom variables can only be read and output from...
Currently, mom variables can only be read and output from individual operations. They cannot be read directly from other objects in the Operation Navigator (i.e. Workpiece). This is why ${mom_part_material_code} can only be used within the template table and cannot be used within the title area. This is a known issue that is currently being addressed by an open problem report. If you wish to display the part material in the title section of your Shop Doc output, you need to use a part attribute:
