How can i change the H value ? where tool number remains same
whenever i give the tool number i get the same value in H also. But l need to change the H value as per my requirement. For example T01 H20  how shall i change the H value and where ?
Re: How can i change the H value ? where tool number remains same
The H value should be inherited by the adjustment register number of the used tracking point.
Give it a try to change that to 20.
Thomas Schulz
Siemens PLM
no luck
Maybe the post has hard coded to output H always with the T number instead of using the adjust register number. You may can check that inside the post.
Thomas Schulz
Siemens PLM
