How can i get feedrate by variable?
Hi
How do I call the parameters of the feedrate before each program?
Re: How can i get feedrate by variable?
to create tab use variables:
mom_feed_rapid_value,mom_feed_cut_value, etc....
to put it into motions:
use custom command with variable mom_motion_type to output what you want.
remove F from block and create new address with what you decide in your custom command.
it should be string, modal
cheers
Suppose you create the variable like Q2 = 1600.; CUTTING FEEDRATE.
What are you going to do with the lines where NX may slowdown this feed to values other than 1600?
Esteemed Contributor
Use Post-Configurator and you can select how to output the feed rate, like NX-value, parameter (this is what you want) or % of cut (if the control supports this).
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
if nx slow down or change feedrate for exmple from cut to retract it changes motion type - it changes Q in F address.
*But if nx slow down cut feedrate (by optimizing) there is no effect in nc code, so in this case it is no good...
So this situation (when optimizing may be) should have another solution, more difficult than yours with static templates.
With a Post-Configurator post even an optimized tool path is not a problem at all.
if think in optimized nc program are several cut feeds - how can we do it parametric? I think we cant.
It is unlogic.
*In volumil somewhere you will get lets say every feed different....the end Smiley Happy.
N0160 G01 X4.6889 Y11.7921 F45.6
N0170 X4.7206 Y11.7888 F91.3
N0180 X6.077 Y11.6468 F91.4
N0190 X6.109 Y11.6434 F45.6
N0200 X6.1452 Y11.6397 F22.8
N0210 G03 X6.3178 Y11.7794 I.0164 J.1562
N0220 G01 X6.3304 Y11.8995 F45.7
N0230 X6.4686 Y13.2142 F91.4
N0240 X6.4723 Y13.2501 F45.6
N0250 X6.4757 Y13.2824 F22.8
Or put before motion a calculation of new paramere Q for cut feed, set it , output it. I see it complicated.
My solution: when opimizing - feedrate by number, dont use parametric feeds.
(or dont use fct optimize feeds)
(Or if machine control accept %feed in address or somewhere ... i think it is possible to program it.)
Can you show us an example of optimized code with parametric feeds by Postconfigurator?
Sorry I don't use optimized feed rates nor parametric output, we just use F AUTO on our Heidenhain controllers.
